V70 code 0305 cyl 5 misfire on a 4 cyl. Help!!!
Old Oct 6, 2017 | 12:03 PM
jessebowen107's Avatar
Default V70 code 0305 cyl 5 misfire on a 4 cyl. Help!!!
My v70 is reading the code p0305 and says slow down or upshift.
The car runs rough, has little power. The p0305 code means cylinder 5 misfire, but it is the 2.4l 4 cylinder.
Any suggestions?
Old Oct 6, 2017 | 11:02 PM
ssicarman's Avatar
Any suggestions?
You should recheck the engine for the number of cylinders. As far as I know the 2.4 LT is a five cylinder.
I could be wrong though. It happens.
Old Oct 7, 2017 | 02:28 PM
pop off the the spark plug wire cover, #1 is closest to the timing belt. #5 is by the bell housing. You can start by replacing plugs but the coil pack is also a likely suspect. Also look closely at the connector to the coil. If you are not sure about the coils, try swapping say 3 and 5 then see if you get a 303 or a 305 code next time.
osage
1998-2000 model year V70
Aug 4, 2016 12:26 PM
adclark1966
Sep 28, 2010 11:05 AM
adclark1966
Aug 17, 2010 07:14 AM
1996Volvo850
Apr 20, 2009 02:50 PM
rgmendoza
Mar 13, 2009 08:39 PM
