V60 Timing Belt Cost
Old Jun 23, 2023 | 03:03 PM
slemieux's Avatar
Default V60 Timing Belt Cost
Hello,
I'm a proud owner of a 2017 Volvo V60, a definite upgrade from my 2008 V70! The mileage on my V60, 2017 is 114,00. At what mileage is it recommended to replace the timing belt and what is the cost, roughly.
Thank you!
Old Jun 26, 2023 | 05:19 PM
Mathieu Colins's Avatar
Welcome aboard
Old Jun 26, 2023 | 07:33 PM
check your owners manual for the maintenance interval chart. From what I saw, the non-hybrid 4 cylinders get a belt, tensioner, idler replacment at 150K miles. I'd expect the cost to be in the 600-800 range depending on the shop. You should also have the accessory/serpentine belt serviced as part of that job. Earlier models also recommended a 10 year interval max as well which I'd say is a good idea here as well. No harm in doing the belt at 120K miles either. Have it done right and forget about it for another 6-8 years.
Old Jun 27, 2023 | 08:36 AM
maggs's Avatar
My 2020 V90 T6 service schedule recommends that the timing belt, etc, be replaced at 10 years or 150K miles, whichever comes first. The attached is the service manual for OP's car. It has the same recommendation.
Historically, on other cars, I've always replaced the water pump at the same time. If the water pump in in the same area as the timing belt cover, I'd change this as well, if it were me.
https://volvornt.harte-hanks.com/man...non-hybrid.pdf
JBoldt
Jun 1, 2025 10:19 AM
urgiv
Feb 17, 2024 02:55 AM
JoeMed
May 3, 2022 09:04 PM
NashvilleAuto
Apr 28, 2022 09:25 AM
