v70 mk2, replace exhaust
Old Jun 13, 2018 | 08:49 AM
atom's Avatar
Default v70 mk2, replace exhaust
i take default exhaust off, and make new cat forward. I put 2 inches mufler because of the little space for a cardan and went on 2.5inch the rest of the exhaust. is that cat -> 2inch ->2.5inch bad idea. is too much distressed ?
v70 mk2, 2.5t awd
Old Jun 13, 2018 | 05:25 PM
going from 2.5 inch pipe to a 2.0 in pipe will cut your flow rate by almost 40%. It's like going from a "5" to "3". Considering an engine is an air pump, if you need a 5 to produce your top HP (lets say your V70 makes 200 HP) and you can only pump through 3 of the 5, your max HP will be about 120 before you start building up abnormal back pressure... in short, a really bad idea.
BlueStrada
2001-2013 model year V70
Oct 24, 2017 09:03 PM
Mike Heinz
Jun 7, 2014 10:55 PM
bluefever
Nov 8, 2011 05:37 PM
litehwk356
Jan 8, 2009 08:03 AM
nandrolone
Oct 6, 2005 12:58 PM
