V70 T5 2001 camshaft position sensor
Old Nov 9, 2021 | 04:57 PM
Paul Freeborn's Avatar
Default V70 T5 2001 camshaft position sensor
Hi, I have a code ECM 644a. Reckon it to be cam position sensor, but I cannot find it !! V70 T5 2001. Can anyone help. Even my Haynes manual got it wrong !! I've got the replacement part, but have trawled the internet for hours and still none the wiser !!
Old Nov 9, 2021 | 08:00 PM
The cam position sensor is on the left end of the cam. (driver side) You will find that the sensor is not bad after you replace it and the code comes back. The code is probably there because the cam timing is very slightly off.
A code does not mean a part/sensor is bad. It means the signal from the sensor is not what is expected. So in the future don't simply replace parts from a code - diagnose why the code appeared.
The T5 is fun with the extra HP!
Old Nov 10, 2021 | 04:14 AM
So, the cam timing could be off. I had a new can belt a few months ago, should I get the mechanic to re do it ?
Old Nov 10, 2021 | 01:32 PM
some light reading
https://www.matthewsvolvosite.com/fo...ic.php?t=58908
Cameron Sawyer
Jan 21, 2020 06:06 AM
emperortortreform
2001-2013 model year V70
Aug 30, 2016 01:22 PM
deltonavolvo
May 4, 2015 04:17 PM
BigV592
Aug 26, 2013 02:04 PM
thatvolvokid
Jul 11, 2013 09:25 AM
