Vehicle ignition on and engine not starting
Hello !
The problem happens when engine is turned off and try after few minutes to restart .
the immobilizer and steering lock symbols appears in the dash.
the steering is locked even if the ignition is on and the vehicle doesnt start .
I have clear dtc’s also but it didn’t start !
the symbols stays there im the dash .
I disconnect the battery and after this the immo and scl symbols dissappears and vehicle engine can be started .
I replaced the Steering column lock module for this problem and programmed to volvo dealer
but same problem still persist !!
Wiring line are ok from CEM to SCL
Dont know what can be the issue of the vehicle
can u please help me in this ?
