Volvo service required
Old Feb 15, 2023 | 08:01 AM
Mickroy's Avatar
Default Volvo service required
I have a 2002 volvo s60 awd and while i was driving suddenly i lost engine power and now i have a wngine service required light on.
and i got these codes p2122 p2121 p0234
Old Feb 15, 2023 | 09:01 AM
The P2121 and P2122 are related to the drive-by-wire set up which uses a throttle position sensor to feed into an electronic throttle mechanism (aka ETM). Some further tests may be required as it could be a relay/fuse, wiring/connector, the position sensor or the ETM at fault. To diagnose ETM issues, check out Xemodex's web site (they repair wonky ETMs). Also here's a good dicussion thread https://www.matthewsvolvosite.com/fo...ic.php?t=92510 You should also check out your system's voltage as low voltage events can cause odd error codes.
As to the P0234, that's an over boost fault that gets set when the boost pressure is like 5 PSI over expected for more than 5 seconds. Could be a waste gate issue, a pressure sensor issue or could be electrical/wiring to a sensor or computer. That's one where I'd clear the code and see if it returns.
Old Mar 5, 2023 | 06:55 PM
Mickroy's Avatar
Where would the position sensor be?
Old Mar 5, 2023 | 06:57 PM
Mickroy's Avatar
I was thinking of getting a new throttle body but i want to make sure that its the problem first before spending that much money
Old Mar 5, 2023 | 08:55 PM
Turbo/non turbo? 2002 non turbo throttle modules - all will fail. 2002 turbo is a bosch, rarely will fail but has external wiring problems. What do you have?
https://xemodex.com/us/electronic-th...etm-for-volvo/
Old Mar 6, 2023 | 06:13 AM
Mickroy's Avatar
I have a 2.4 turbo but i also have a 2.5 that is busted idk if they are interchangable
Old Mar 6, 2023 | 10:38 AM
to determine if parts are interchangeable start by using a dealer web store or a Volvo friendly web site to see what part numbers they list for the two engines you can also try to find an OEM part number right on the component itself.
Old Mar 6, 2023 | 07:11 PM
Mickroy's Avatar
I have changed my throttle body and the problem persist making me think it may be the connectors or wires. Also would there be a fuze that i could check
Old Mar 6, 2023 | 08:14 PM
Yep, sorry, tried to warn you - from my experience - there's a connection problem - perhaps that's why the xemodex throttle - (link from earlier) comes with a wiring harness. (because it's not the throttle that's the problem in the first place - it's a wiring/connection problem)
Old Mar 9, 2023 | 11:30 PM
Mickroy's Avatar
yeah i will be looking at all the grounds if i can find then incase its just a simple fix like that
Old Mar 15, 2023 | 09:54 PM
Mickroy's Avatar
was wondering if i would bring it to a mechanic if it would be something that would be too expensive for a mechanic to find the wiring problem or they would be able to find it easy i dont want to have a huge bill after i get them to find it.
Old Mar 15, 2023 | 09:55 PM
Mickroy's Avatar
both my codes give me throttle.pedal position sensor/switch D Circuit rage/ performance and low input
iehuiah
Mid West
Sep 13, 2022 03:10 PM
pointer95
Sep 7, 2022 06:24 AM
durch
May 10, 2009 03:17 AM
creamsoda
Oct 18, 2008 05:28 PM
chrissygm
Sep 30, 2008 05:53 PM
