xc90 wiper problem
Hi, the front wipers on my xc90 do not work. Dealer has run diagnostics. Wiper motor is ok, but problem is in 'electronic central unit' or something like that. That should be replaced, but it needs to come from Sweden, has to be programmed specifically for my car and will cost around euro 2k .... So too expensive for my xc90 from 2008. I can't sell the car because it will not pass the inspection. Does anybody have a suggestion? The car is running fine and I hate to scrap it just for this wiper problem! Thanks!
The CEM (central electronic module) is a common electronics control unit that contains relays for various components. Not sure where you are located but the part is readily available in the states for about $700 US. With that said there's two other options - find a recycle yard for a used unit. You dealer may need to program it as some models/years have the CEM paired to the central computer. A second option is to find a service such as XeMODeX who rebuiilds the units. The most common fairures of CEMs are either cracked solder joints which can be resoldered or the relay component for a specific function burns out and will need to be replaced. This typically costs $250 US and does not require dealer programming since its the original unit. Down side is you'd need to remove the unit to send out for repair. Google around for various repair services, they should be easy to find and instructions for removing the CEM can be found on Youtube.
