Boost Control
RE: Boost Control
ORIGINAL: S70driver
Well on the T5 atock your running like 10PSI right? I would up it to like 15 PSI at the most.
Also I do reccomend that you do not use a MBC. I would get a ECU upgrade, which is a lot better and can control the boost better.
RE: Boost Control
ORIGINAL: gdogg16
If he's going to be using a electronic boost controller, how is he going to use a MBC and why?!
ORIGINAL: S70driver
He said not to use an MBC, so there is no explanation of how to use it. But who really cares as the original topic is over one and a half years old.
RE: Boost Control
ORIGINAL: S60 R
He said not to use an electronic or manual boost control. What he and others have said is to get an ECU upgrade for newer Volvos.
ORIGINAL: gdogg16
That's exactly my point, why would you use both an EBC and a MBC?
RE: Boost Control
Do NOT get a manual boost controller....one word... JUNK!...save your $ and pick up a good Electronic Boost Controller. On a MBC there is no selonoid to control the wastegate, often leading to boost spikes etc... save your $ and your $ EBC or ROM tune!
Check out Greddys Profec B Spec II manual boost controller, you can pick one up for around 330.00 new. Great EBC for the $!
05, 1998, 2005, adjustable, boost, control, controller, electric, electronic, manual, me7, s60r, s70, t5, volvo
