Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Boost Gauge
Old Mar 27, 2005 | 12:57 AM
speewee21's Avatar
Default Boost Gauge
I have a 2001 S60 and i was wondering how to wire up a boost gauge? I am buyin the pod but i need some help with the gauge.
Old Mar 27, 2005 | 04:22 AM
alecw81's Avatar
Default RE: Boost Gauge
There's this great new innovation online called "Google" I won't be a complete *** though:
The boost gauge plumbing is installed somewhere between the compressor outlet of the turbo and the intake manifold. A hole is drilled through the firewall and deburred so that the pressure tube can then be routed to the gauge. Several layers of electrical tape or a grommet may be installed to prevent damage to the tube by the firewall. The tube is then routed to the back of the gauge and mounted to the fitting on the gauge. Extreme care should be made in routing and connecting the tube so that no kinks are experienced. The gauge light is then wired into the existing instrument light switch (12VDC) using 18 AWG or larger wire (not supplied with gauge/tubing kit)
That's just a "Universal" guide for installing a boost gauge. I installed gauges in my 2 previous DSMs, I've yet to install one on my S70, that'll be remedied shortly.
Old Jan 21, 2006 | 07:41 PM
S70driver's Avatar
I would run the wires and lines through an existing route to under your dash, then run them to the gauge.
Old Apr 25, 2006 | 12:51 PM
gdogg16's Avatar
there is usually conduit installed under the dash up in the driverside kick panel. It will let out just under the fuse box on the driver side and ill have a rubber cap on it. Just pull it off and fish your hose through. Tap into the line coming off the intake manifold for boost.
see here
http://img.photobucket.com/albums/v1...intakemani.jpg
Old Apr 25, 2006 | 08:52 PM
ORIGINAL: gdogg16
see here
Sweet engine That is an R correct?
Old Apr 26, 2006 | 03:28 PM
gdogg16's Avatar
Correct, it's my former '99 Laser blue V70R AWD. Sold it a few months ago.[&o]
Old Apr 26, 2006 | 09:36 PM
Thought it was A V70R.
Not many people buy the colored Covers.
Old Apr 27, 2006 | 03:03 PM
gdogg16's Avatar
ORIGINAL: tech
The paint color on the shock towers should be a dead give away too. :P
Old Apr 27, 2006 | 08:59 PM
That to Yes!!
Old May 4, 2006 | 12:15 PM
CSudhoff's Avatar
*Tip
try to install the vac line as close to the compressor side of the turbo for the most accurate reading.
559s40
Jul 13, 2012 10:50 PM
ibified
May 26, 2011 01:03 AM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
