Factory PSI
RE: Factory PSI
As Tech has said you can just do a basic Boost Controller Install. You can either go for the mechanical kind, which is installed right into the vacuum line (sp? lol), which is a very simple install or you can go for an electronic kit which requires a little bit more work.
What PSI are you aiming for? Cause you can't just install the controller and crank out 15psi without doing other work on it first. This ain't no Fast and Furious![:'(]
