Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Twin turbo in an s80?
Old Jan 14, 2009 | 12:17 PM
imhereftw's Avatar
Default Twin turbo in an s80?
I'm driving a 2004 s80 2.5t awd.
Is it possible to install an additional turbo with the stock turbo or would I have to replace the stock one with an aftermarket.
Thank ya =]
Old Jan 14, 2009 | 12:21 PM
Default RE: Twin turbo in an s80?
You can go with a bigger turbo.
Not exactly sure which one you have in there now but you can go bigger. I would also get the ECU programmed as well.
Old Jan 14, 2009 | 12:26 PM
imhereftw's Avatar
ORIGINAL: tech
Thanks, yeah sorry I can't give much information just started looking into this, how exactly can one go about getting their ECU programed?
Old Jan 14, 2009 | 12:35 PM
TIPSP's Avatar
Got Boost?
ORIGINAL: imhereftw
You can get a chip which you install.
You can get a kit which allows you to read the Maps and then you send you info to the company and they send you the new maps which you then flash to the ECU.
You can send in your ECU to a company and they do it for you.
Check here for tuning companies: https://volvoforums.com/m_38606/tm.htm
Old Jan 14, 2009 | 12:36 PM
Ipdusa.com does them.
Also check out the resources thread there is a few more link to sites that do them.
Old Jan 14, 2009 | 12:48 PM
TIPSP's Avatar
Got Boost?
Your car should have twin turbo:
Old Jan 14, 2009 | 12:49 PM
ORIGINAL: TIPSP
You car should have twin turbo:
He has a 2004 with the 5 cylinder motor.
Old Jan 14, 2009 | 12:56 PM
TIPSP's Avatar
Got Boost?
Ah...Ok
So what year/model got the Twin turbo Striaght six?
Old Jan 14, 2009 | 01:01 PM
The S80 from 99 up to I think it was still an option in 2003 or2004. Also the first year or 2 of the XC90 had the T-6 as well.
Old Jan 14, 2009 | 01:30 PM
S70driver's Avatar
It will cost a lot of money to do a twin turbo setup on your S80 and you'll end up spending more then the car will eventually be worth.
I'd suggest a single turbo upgrade or just do a full turbo exhaust upgrade and ECU upgrade from IPD USA or RICA (ECU that is). I'd have the turboback exhaust done by a local shop that can mandrel bend. 3" downpipe to a 2.5" to 3" mandrel bent catback system with a free flowing muffler such as a BORLA or Magnaflow.
Old Jan 14, 2009 | 03:04 PM
imhereftw's Avatar
ok, sounds like I'll stick with just the ECU upgrade (will save me money too), I'll look into that.
Thank you guys
xamadeix
Jan 5, 2022 10:12 PM
porkchop112699
Jul 29, 2015 01:42 PM
Willymac28
Mar 7, 2013 09:57 AM
Graphxxx
Feb 25, 2012 12:30 PM
tmlonghorms
Oct 5, 2010 07:51 PM
