it is done
Old Jul 26, 2006 | 07:08 PM
  #21
cbevis's Avatar
Default RE: it is done
oi...then I"LL start a new one....tomorrow...i gota go pick up me wifle....
Old Jul 26, 2006 | 07:10 PM
  #22
luckytweaker's Avatar
a wifle ball or a wifle bat??
Old Jul 26, 2006 | 09:19 PM
  #23
Damb I guess I am on my Own I wanted a Nice custom door panel lined with Speakers.
Old Jul 26, 2006 | 09:32 PM
  #24
yes you are tech....lol
Old Jul 27, 2006 | 12:08 PM
  #25
cbevis's Avatar
Sorry broham....just duct tape some speakers to the car door......it'll be fine, you car is mostly silver anyway.
Old Jul 27, 2006 | 11:45 PM
  #26
ORIGINAL: cbevis
Thanks alot!!!
Old Jul 28, 2006 | 11:59 AM
  #27
cbevis's Avatar
where are the speakers located exactly and what kind of speakers did you want to replace them with?
Old Jul 28, 2006 | 10:45 PM
  #28
Originally it had none but the hole was there.
I installed a Set of pioneers.
Kind of hard to see but look for the grill in the door panel. I think they are 5 inch behind there.
my box
Amps
Radio and EQ
Old Jul 31, 2006 | 11:32 AM
  #29
cbevis's Avatar
...well, you could do what i did and throw a set of 6x9s in the doors instead. I just cut the plastic bigger and mounted them on the out side with a speaker cover hiding all the mucked up plastic. They were originally 4x6s...bad engineering on GMs part...4x6s are crap. Your speaker enclosure looks like it's low enough to accomidate for the window so it should still work. However, you may need to cut the metal behind the plastic to fit the magnet....if you were to to something like this, it looks like you'd have to move the speakers over a bit.
Otherwise....a new fiberglass door panel would look pretty sweet...it'd be a little easier than that damn dash piece i did since there's room to move it around. If i had a fox body door up here someone would be willing to to let me play with (and a separate workshop....my garage still smells like 'glass) it might be a fun project!
Old Jul 31, 2006 | 08:54 PM
  #30
I know it would be sweet I have seen a couple done like that. I would love a setup like that but Me I wouldn't even know where to start.
Old Aug 1, 2006 | 02:08 PM
  #31
cbevis's Avatar
with an idea, pencile and a dremel tool.
Old Aug 2, 2006 | 09:42 PM
  #32
But I guess I would have to make a Wooden Part first then put the fiberglass over it?
Thats where I am Lost. It would be nice to have something from back to front at the bottom of the door panel.
Will be buying new panels soon as well.
So if I had something made I could just transfer.
Old Aug 3, 2006 | 11:32 AM
  #33
cbevis's Avatar
You wouldn't need to make a wooden mold for something like this. the way i'd do it would be to take your door panel off and wrap it in selphane (sp?) +/- a little duct tape to make all the pockets. Then...because you've got such a large area to cover, i'd use the liquid resin stuff as opposed to the jelly i used. That enables you to soak the fiberglass sheets in a tub of the stuff and then lay it on the mold. it'll be messier but it'll make a better form and it'll get stiffer. It wouldn't be a bad idea to put some chicken wire behind it either....fiberglass it really flexable (or just put a bunch of layers of 'glass on it). If you're going to get some new door panels anyway, putting some screws or staples in your panels to keep the chicken wire in place may not be a bad idea. You could just grind em off from the other side when the fiberglass set.
That's how i'd do it anyway. I ran into a problem with the chicken wire poking through the fiberglass because of how much i was sanding off. I should have put more 'glass on it i guess.
anyhoo....i've gone on long enough.
Old Aug 3, 2006 | 11:22 PM
  #34
Thanks one Day I wil give it a try.
S70driver
Jun 5, 2006 02:27 PM
auburnvolvo
Jun 5, 2006 02:19 PM
Mass850
Feb 22, 2006 10:44 PM
colgate41
Dec 16, 2005 08:54 PM
Qamar
Aug 8, 2005 02:32 PM
