Having a problem
Old Aug 18, 2022 | 11:47 AM
Alicia.cusano930's Avatar
Default Having a problem
I’m literally stumped. This is what it does when I turn the key on and off trying to get it started.
Car ran absolutely fine no lights came on or anything no codes, nothing.. Turned the car off now it won’t start again. Turn the key, fuel pump engages, fuses are fine. Figured it was the starter, threw a new one in and it’s doing the same damn thing 🤦🏽‍♀️
Checked starter by jumping it, it spins even without jumping it. Checked alternator it's fine, tried jumping the car didn't work.
Battery and connections have plenty of juice. Alternator is fine.
File Type: mov
Old Sep 17, 2022 | 03:54 PM
drttt77's Avatar
Will suggest you contact a specialist
Old Sep 19, 2022 | 11:48 AM
avensis's Avatar
Hi, that's weird, I don't see what it could be, everything looks fine.
Old Sep 19, 2022 | 12:48 PM
Sorry to hear you just "threw a starter in there" without doing some further tests. Did you check the power cable to the starter? Some models have a fuse in there. Also did you check the battery voltage? what does the voltage do when you go to crank it? Did you try a jump start?
Old Sep 20, 2022 | 04:47 AM
drttt77's Avatar
That sounds weird
Old Sep 20, 2022 | 09:45 AM
Alicia, what year/model/engine for your car?
sn99999
Apr 11, 2022 07:54 AM
Christian Sætre
Apr 28, 2021 02:39 PM
TeachTomCR
Forum Issues
Sep 27, 2017 01:16 PM
rspi
Jun 21, 2014 08:45 AM
breatlevo
Oct 24, 2012 08:48 PM
