Locked out
Old Aug 18, 2020 | 11:32 AM
Bernardc22's Avatar
Default Locked out
I have a 2008 Volvo xc70 every so often when I lock the doors and return I'm locked out. The remote or the key bar will not unlock the door. I have changed the battery in the remote and it still will not open the door. I don't understand what could be causing it to happen or how to fix it and why the key bar won't open the door. It cost $90.00 every time I call a tow truck to open the door. Once they open it with the lock out kit everything works normal for a while. Please advise!
Old Aug 18, 2020 | 01:56 PM
If you are saying your emergency key does not unlock the car when you turn it in the tumbler in the drivers door - there is a cable from the tumbler to the inner door lock that could be a problem. I know that does not fix your remote not working but, you would be able to unlock the car if you got the keylock mechanism fixed. It take a couple of hours to take the door apart and put it back together -
Old Aug 19, 2020 | 09:30 AM
Bernardc22's Avatar
Thanks!
Old Feb 11, 2021 | 04:19 AM
AlexNillson89's Avatar
I had this and just like you just changed the battery, I don’t understand why it didn’t work for you (((Good luck, because this is a sad situation
goto
Feb 8, 2016 08:05 AM
rspi
May 27, 2013 02:22 PM
pooky85
Apr 7, 2011 08:53 PM
96960Chris
Mar 24, 2010 12:11 PM
