Why can't I change user-specific folder and variable names?
Old Apr 22, 2009 | 04:57 AM
Hansika's Avatar
Default Why can't I change user-specific folder and variable names?
Is there any way to modify or delete a 'user variable' on XP Pro without login to the account?
The story is this. I got a laptop repaired but the OS (together with defective speaker and audio board) was re-installed. The problem is the Windows was installed with a username which I would like to replace. Doing through Control Panel-> User Account was successful.
However, %USERPROFILE% and %HOMEPATH% still point to the wrong folder. I managed to modify %HOMEPATH% through "Local Users and Groups" -> Users, but %USERPROFILE% remained not pointing to the new folder under C:\Documents and Settings. Then I decided to add USERPROFILE in 'user variable' to override the value used by XP. Now I can not login any more through regular reboot or safe mode. I still can login as Administrator.
How do I delete USERPROFILE that I created? From regedit, it seems I can only access Environment Variable (user variable) defined by Current User.
Old Apr 22, 2009 | 10:11 AM
01_fast_ride's Avatar
You're trying some pretty advanced stuff there. Have you thought about the basics, like deleting the previous user and creating a new user? Seems like that could solve the problem with not being able to login and deleting USERPROFILE. That is what I would try first.
Old Sep 3, 2010 | 08:33 AM
conorg's Avatar
No there actually is no way of doing it
jujudude
Jun 30, 2025 11:19 AM
johnwartr
Feb 21, 2014 04:12 PM
foobar
Dec 3, 2013 10:35 AM
keaunym
Feb 11, 2009 02:10 PM
rallymodeller
Jun 23, 2005 06:03 PM
