Volvo Penta 3.0 GLP Stalling when reducing from high RPM.
Good day all, I知 currently having an issue with my Volvo Penta 3.0 GLP engine. The Engine starts without any issues and is running fine when at High RPM on the plane. However, as I reduce the throttle to slow down the engine is wanting to stall. I知 able to keep the engine running if I throttle down very slowly and gradually. If the engine does stall then I知 able to start it again without issue. I was thinking that this may be a carburetor issue and I would be grateful of any suggestions as I start at looking to resolve the issue. All other indications, oil pressure, temperature, voltage etc are all normal, however the idle RPM does seem at little high, around 1000RPM.
