volvo TAMD41a - oiling issue on rocker shaft
Hi there, TAMD41A, doesnt look like enough oil is making it up to the rocker arm. Is there a an external supply line I can check? Oil psi has been verified with manual gauge.
Thanks
Thanks
Whole upper is dry, like an engine that stood for 4 years. There was a squeak, and I worked my way down with WD40 to see where it was coming from. on the 3rd set of rockers it went away - so it was dry despite being run hard. There was not a sign of oil in the rocker area... looked very dry
