'79 242 2 pc. Driveshaft Issues
Old Aug 23, 2014 | 04:23 AM
79gt's Avatar
Lightbulb '79 242 2 pc. Driveshaft Issues
Hello everyone,
This is a great site. I've been learning so much I've decided to register and become a member.
Now down to business. I have owned my '79 242 for over half a decade now and, since I became the proud owner I have had one major issue plaguing it.
*The owner before me managed to break the drive shaft at the first u-joint mount. He had it welded back and I have had it rebalanced and installed a new carrier bearing and support since. She still vibrates badly which has caused all kinds of havoc to the transmission. I don't think I will ever find another drive shaft. None online for sale. However the junk yard down the road has half a dozen old 240's with single piece drive shafts. I looked under them the other day and noticed the mounts are very different. Does anyone have any thoughts on switching to a 1 piece they would share? Maybe different lengths or would the output shaft from the transmission be the same diameter as the 86-88sh.*
Any thoughts would be greatly appreciated.
*If someone out there would sell me a two piece drive shaft. I would be very happy.*
79 GT
Old Aug 23, 2014 | 10:18 AM
act1292's Avatar
I don't know where you are located but I know of a complete '80 242 GT barn find in northern Indiana. Hasn't been run in about ten years. PM me if you are interested.
Old Aug 23, 2014 | 12:42 PM
note that manual vs automatic transmissions use different length drive shafts, ditto 4 speed vs 4+OD manuals (and I think BW vs AW automatics).
Old Aug 23, 2014 | 02:15 PM
79gt's Avatar
I don't know the difference between a BW and AW, but I do know I have an M46 trans 4+OD. Parts are being sourced to replace the seals and gaskets the drive shaft has vibrated loose. I plan on having the trans done this coming weekend but, I sure hate to waste my time just for it to happen again. *I'm holding my breath that ACT1292 has the drive shaft I have been looking for since day 1.*
Old Aug 23, 2014 | 02:35 PM
early volvo automatics were BW55 or whatever, later ones are AW70/71. Borg-warner, and Aisin-Warner (Toyota's transmission factory which started as a borg-warner joint operation).
anyways, if you find a junkyard drive shafts, make sure they are off a 240 from ANY year with the M46 4+OD, and you should be good to go. There's a volvo parts dismantler in Rancho Cordoba, California (near Sacramento) who probably has these in stock.
Old Sep 5, 2014 | 02:07 AM
79gt's Avatar
I have sent them an e-mail hoping for the best, but only time will tell. If you can think of any other dismantlers I would appreicate any info.
Old Sep 5, 2014 | 01:33 PM
Bumblebeeman's Avatar
Originally Posted by 79gt
Hello everyone,
79 GT
Correct me if I'm wrong here, but i have never seen any single piece driveshafts on a 240. i could be way off base because i have never seen the underside of a '79 buuuuuuut i think they are all 2 piece with the part that connects to the tranny actually being different from Manual or Auto. you should be able to source a drive shaft by finding a car that had the same transmission as yours...
If you find a donor car with a M46 Transmission, take the whole drive shaft. It should bolt right in place... That will be all she wrote.
Side note: the Windsor location pick-n-pull here in Northern CA has right now, several 240's with M46 transmission if you are near northern CA...
Hope this helps
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
awdMN
Nov 28, 2010 09:08 PM
dragon19a
Jan 15, 2007 09:19 PM
Walter J.S.
Apr 16, 2006 10:12 AM
Eli_T
Jul 1, 2005 03:26 AM
