Sights N Sounds Post all of your video and sound clips here.
Encyclopedia Thread
Old Nov 28, 2011 | 08:11 AM
Digmenow's Avatar
Default Encyclopedia Thread
I have created this thread to have a place to stash and test pics for uploading. The picture files below were too large to use as attachments so for now, I'm linking them to Photobucket.
The following will be reposted in the appropriate thread once I'm sure the format works. There will no doubt be more posts in this thread as issues with the car arise.
Here is the left (driver's side) headlight wiper/washer on my '00 V70 XC. The P.O. snapped off part of the bracket that holds the wiper when they tried to replace it and were apparently stumped on how to fix it. Enter Dig.
Note that I have already wiggled the fluid hose and removed it from the nipple which is just below the headlight to the far right in the pic. For photo reference purposes, I placed it back into position without actually fitting it back over the nipple.
The cap that covers the nut on the wiper stem flips up for easy access.
It's probably metric but I used a 5/16th socket and ratchet with no problem when I removed the nut.
The arm is mounted on a shaft with a tapered spline so you'll need a pair of pliers to grip and wiggle it to pull it off.
Voila! Ready to reverse the procedure to install the replacement. It's off to the "Pick 'n' Pull to see if I can find one.
Note the tapered spline.
Size:  66.0 KB[IMG]https://volvoforums.com/forum/Name:  IMG_20111128_080032.jpg
Old Nov 29, 2011 | 12:15 PM
Digmenow's Avatar
Handy links that I want to keep around.
TECH TIP #10072 - Reset Service Light in 1998 & Later Volvo Models
TECH TIP #10061 - Fuel Pump Whine - 1998-2000 V70XC Models
jhonny.drift
Jul 16, 2012 06:20 AM
S70driver
Feb 9, 2009 06:23 PM
S70driver
May 10, 2006 02:00 AM
flamejet
Mar 8, 2006 06:30 PM
