Sights N Sounds Post all of your video and sound clips here.
Help me
Old Jul 2, 2017 | 03:55 AM
Troy Gater's Avatar
Default Help me
i have a XC90 2009 with 3.2ltr. And I have a squealing noise coming from my engine.. When I pull the dipstick out it goes away and if I put my foot down.. It is getting louder need to fix.. Help Troy
Old Jul 9, 2017 | 01:07 PM
pulling the dipstick will vent crankcase pressure. the noise is likely an air leak somewhere that needs to be traced. I'd also test for excessive crankcase pressure (you can try removing the oil fill cap, then put a latex (ie surgeons) glove over the oil filler - if it inflates and stays inflated, you have positive crankcase pressure, which could be caused by a clogged PCV system. (and you'd want to fix that before it starts turning into leaky oil seals)
shop2
May 1, 2011 07:32 AM
lydjan37
Sep 13, 2010 07:11 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
