Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and talk about it here.
Squealing when I brake that goes away
Old 12-24-2007 | 10:10 AM
guswitte's Avatar
Default Squealing when I brake that goes away
Hello, I am new to the forum. I have owned my 1994 850 Wagon non-turbo version for the past 4 months or so. I bought the car from a dealer with 120K miles under the hood. I immediately had a transmission fulsh, oil change, rear brake job and had the timing belt replaced (since it was never replaced). All has been well, except for the past month I have noticed when I first start the car and apply the brakes, my right rear wheel squeals (and I mean loud) whenever I apply the brakes. After the car rolls for a little bit the squeal goes away completely. I have heard various opinions and will take the car in for a check-up but wanted to see if anyone might know what the problem is before I take in (so I don't go in blind). Some have said rust or something else on the new brake pad, and others have said the wheel bearings lubrication is going bad? Any opinions would be appreciated. Thanks!
Old 12-24-2007 | 02:29 PM
Default RE: Squealing when I brake that goes away
Do you use the e-brake?
Old 04-09-2008 | 11:53 PM
hitwriter's Avatar
My s80 did the same noise, somebody mentioned to me the brake booster.
mikaa21
10-19-2013 06:05 PM
fmscott2
09-10-2013 07:30 AM
artbar92706
10-27-2012 10:48 PM
Quick Reply: Squealing when I brake that goes away
