@##&**!! tail lights are inop.
Old May 31, 2016 | 09:37 PM
mjohansson2's Avatar
Default @##&**!! tail lights are inop.
Hello all, I ordered and received a new circuit board for the Volvo 240 Rt Rear tail light as I have no break lights. Now I see I have no break lights at ALL only the third light in the rear window. I have turn signals, and even a new circuit board, so what could be the problem? fuse is good, and the I thought about the stop light switch, but the third light works, so.....
What do you all think the problem could be?
Frustrated in Oregon.
Old May 31, 2016 | 11:48 PM
brickrunner's Avatar
I don't know if this applies to the 240's but on the 940's behind the ashtray there is a bank of relays. The red cylindrical relay tends to be the culprit when the rear brake lights don't work. I know this because I had to replace it once.
Old Jun 1, 2016 | 12:03 AM
Dead_Eric's Avatar
Check the light bulbs, had a van in today with brake light issues... $400 advanced diagnostic later and he had put in a single filament bulb in where he needed a double. Fouled the whole lighting system... his brake light switch was bad too but that doesn't seem to be the case with you.
Old Jun 1, 2016 | 01:05 AM
Default cursed tail lights....
Thank you for the reply, I went to a junk yard and grabbed 5 "new" sockets, as I had a strange all white one in one of the places, and it was cracked anyway so a replacement is in order. I have a multi meter and will check at the plugs tomorrow. If I need to, how does one remove the stop light switch on the break pedal?
Thanks, and God bless.
mike
Old Jun 1, 2016 | 02:06 AM
I seriously doubt that all of the sockets went bad. You need to look into the light bulb failure relay that I mentioned. The part # is KH-1362370. It might not be that but usually when someone on this forum has a problem with the brake lights it ends up being either the relay I mentioned or the brake light switch that is located by the brake pedal and is easy to check.
Old Jun 1, 2016 | 04:40 AM
dytha99's Avatar
The white socket is for the passenger side. Why it matters lm not sure.
Old Jun 2, 2016 | 07:10 PM
Thank you all for the help, I ended up using the owners manual and replacing several of the bulb sockets as I had several wrong ones installed, and one bad bulb. Ops check good.
Old Jun 4, 2016 | 11:41 PM
That makes sense, I knew so many of the sockets could not have gone bad.
88740gle
Nov 13, 2015 08:13 AM
gtjoe
May 29, 2013 11:52 PM
gtjoe
May 19, 2013 06:17 PM
buellfire
Jun 20, 2009 12:37 AM
