`92 240 stationcar starting problem
Old Jan 19, 2010 | 09:13 AM
RLarder's Avatar
Default `92 240 stationcar starting problem
Recently my 240`s Lambda warning light came up- I continued to use the car, 3 days later it began missfiring in low revs, a couple days after refused to start from cold. My mechanic changed plugs leads and distributer cap/rotor, when I got it back the Lambda light was out and the car ran fine.
The Lambda light then came back on after a couple days, and the problem repeated itself, exactly the same pattern.
This has now happened 4 times, the mechanic seems to be at a loss.
At some stage in the proceedings I have also tried a known good HT coil, no joy there either.
Any ideas anyone?
Old Jan 19, 2010 | 05:09 PM
fredbyte's Avatar
I believe the Lambda light has to do with the Oxygen sensor. It's located under the exhaust manifold or exhaust header pipe (can't quite remember which at the moment).
rjdaaa
Oct 18, 2014 09:12 PM
RockyRoller
Mar 18, 2014 09:17 PM
JJR
May 26, 2009 05:07 PM
TedP
Feb 12, 2007 01:31 PM
