1 headlight wonder
Old Jan 2, 2014 | 08:11 PM
420DL's Avatar
Default 1 headlight wonder
so the other day i was driving behind my friend, he called saying 1 of my headlights was out, then he said it just turned back on, i checked it later and it was a little loose so i tightened it and it worked for a couple days, then last night it wouldnt
just the drivers side low beam is out, both high beams, corners and turns all work. the bulb is ok, it works on the other side if i switch them.
i tried putting some grease in the socket with no luck.
any ideas? if it were the relay wouldnt both low beams not work?
'90 240 wagon btw
Old Jan 2, 2014 | 08:49 PM
the relay, which is up by the headlights, the low beam circuit actually is wired back to the bulb-out sensor behind the dashboard, and there it splits and goes to the left and right headlight.
at the high/low 'step' relay, pin 56B takes a grey wire to pin 6 of that bulb-out-sensor... pin 2 of the BOS is a blue wire to the left lowbeam, and pin 7 is a blue wire to the right low beam.
drawing shows no connectors in between the bulb out beercan and the headlights, but who knows?
it also could be the ground wire at the headlight bucket, each side is grounded separately, to a ground on hte inside of the fender. looks like the left ground is near the relay/positive terminal mounting bar. the ground wires are black.
Old Jan 2, 2014 | 11:53 PM
420DL's Avatar
thanks for the reply, the ground is good, so do you think it is the relay? the blue wire between the relay and driver light is in good condition
Old Jan 3, 2014 | 12:54 AM
there is no blue wire between the headlight high/low step relay and the headlights. there is a grey wire from the relay back to the bulb-out-detector under the dash, then 2 blue wires from the bulb-out thing forward to the two headlights.
ZIGZAG
Jan 4, 2016 08:09 PM
Goldie88
Jan 13, 2015 06:36 PM
akabond
Aug 14, 2012 10:45 PM
Sofar.
Jan 18, 2010 07:50 AM
Webfoot_Wa
Mar 12, 2008 08:50 AM
