1978 Volvo fuel pressure spec
Old Sep 15, 2013 | 12:57 PM
Travanion's Avatar
Default 1978 Volvo fuel pressure spec
Hello fellow Volvo enthusiasts, I am looking to buy a 78 245 in AZ, I'm in CO. Yes it is going to be an adventure. The gentleman is asking a very reasonable price for the car but it is not running. The car is getting spark and has had both fuel pumps replaced but I get the impression that the main pump is not an adequate one. I don't have a way to haul it back to CO so I'm hoping to slap a pump in it, it was a 90mile a day commute driver until the fuel issue, and drive it back to CO. My question is does anyone know what the main pump pressure is for this car? I have a VW Rabbit CIS pump and I'm wondering if this pump would make the Volvo run. Any info would be greatly appreciated. Thanks
Old Sep 15, 2013 | 02:32 PM
AnEskimo's Avatar
I belive is 42 psi from the pump. 78 had the mechanical fuel injection system. My 80' 242 had and still has fuel problems revolving around the fuel distributor. I would start by pulling the injectors out and cleaning them, when I got my 80' injector #4 was completely clogged and had to clean it to drive. There is also a fuel distributor adjustment screw. It is a 3mm or 4mm Allen head. The kjet system is very sensitive to vacuum leaks, and the fuel distrubutor can be adjusted to accommodate vacuum leaks until the problem is resolved. Good luck with your classic Volvo!
Old Sep 15, 2013 | 04:44 PM
Travanion's Avatar
Thank you Sir
Old Sep 15, 2013 | 09:52 PM
42PSI is LH. the K-Jet CIS stuff is more like 65PSI.
Old Sep 16, 2013 | 10:58 AM
Travanion's Avatar
Thanks Pierce, that helps a great deal, and bummer the VW CIS pumps only go up to around 35PSI.
Old Sep 16, 2013 | 12:14 PM
um, you sure? its the same CIS system, used in Mercedes, Volvos, VW/Audis, even Ferraris.
Old Sep 16, 2013 | 05:05 PM
Travanion's Avatar
No not sure but the control pressure chart for the VW says the control pressure max out at 35 PSI @104degrees. To me it looks like the Volvo system is a little more stout. Maybe you would know, can you use the brass 1990s MB injectors on the Volvo like you can on the VW?
Old Sep 16, 2013 | 06:22 PM
ah... the control pressure is, afaik, not the same as the fuel pump pressure.
I'm looking at TP30454-1 now, "CI System B19,b21,b23 240 1975-"
ah. line pressure is 65-77 PSI (except turbos are 75-85psi). rest pressure is 22-35psi 82+ turbos are 35-46 psi). control pressure is quite dynamic, depending on altntide and ambient temperatures.
the proper fuel pump is rated at 100 (1975-79) or 120 (1980+ non-turbo) liter/hour at 72PSI.
Old Sep 17, 2013 | 08:01 AM
Travanion's Avatar
Thank you Sir, you have given me knowledge and hope.
MntnDewMan
Apr 3, 2024 04:05 PM
kurtyboy
Feb 21, 2011 08:01 AM
kurtyboy
Nov 9, 2010 06:18 AM
cb1313
May 23, 2009 11:49 AM
whiteliar
Oct 11, 2007 08:45 PM
