1979 242 misfire
Old Aug 31, 2008 | 12:14 AM
sdwelder's Avatar
Default 1979 242 misfire
1979 242, lambda sond, b21f engine. car was given to my gf and it is in great shape, it has been very reliable, when she got it I notices a vibration at low rpms. later I replaces the UV joint closest to the nose cone of the Automatic tranny to fix the problem. I have replaced the o2 sensor, fuel filter,plugs, wires, rotor,cap primary coil, alternator brushes, steering rack, in-tank pump,main in-line 12v pump,fuel filter, a couple vacuum lines, change the oil/filter on reg basis. It has a miss under load, a hesitation that is stumping me. I checked the timing for the first time yesterday and it was at 20deg btdc!! I retarded it back to 8btdc (what the sticker says under hood) when I check the timing the mark does not do anything when I pull off the vacuum line off the advance capsule, could it be frozen in the advance state? i'm almost out of adjustability on the throttle/idle adjustment screw, that is why I question that. I think the next thing for me to replace is the reluctor and pick-up coil in the dist. what about the ignition control module? could that be bad? I always thought those were working or not, no inbetween. I have the hanes service manual so I have schematics. I want to completely rule out ignition before I go into the realm of fuel injection. thanks in advance for your help!
analogies
Jan 6, 2013 03:41 AM
242nick
Feb 19, 2012 02:06 PM
greentabby701
Jan 18, 2011 08:32 PM
Alobar
Aug 2, 2010 10:19 PM
volvo 4 life
Aug 9, 2007 07:55 PM
