1980 242 lower analog radio removal...
Old Mar 2, 2012 | 10:34 AM
AnEskimo's Avatar
Default 1980 242 lower analog radio removal...
This may seem silly but I'm having difficulty replacing the broken factory radio in my 1980 242. In the manual I have it says analog Radios up to 1980 you remove the volume and radio tune ***** to reveal set bolts you take out to release the radio, but when I take the ***** off there is nothing of the sort. If I try pulling the radio it moves freely about a half inch then gets caught but I have the exact same radio to replace it with and after inspecting it I cant see what would he stopping the radio from coming out smoothly. Do you. Have to remove the side panels to the dash to pull it out? Thanks a lot and as mentioned this is a 1980 242 with the radio mounted by the gear shifter under the ash tray and it is the stock factory radio.
Old Mar 2, 2012 | 05:35 PM
AnEskimo's Avatar
Well I got the old radio out and got the new one in but now km not getting any power...its plugged in tight just wont turn on..any ideas?
niurik
Aug 26, 2013 10:56 AM
coolson
Jul 4, 2010 11:17 PM
jessewvu
Feb 13, 2008 06:06 PM
Clueless Scott
Jun 28, 2006 09:45 PM
