1982 245 gl no start
Old Oct 1, 2011 | 06:51 AM
grimvito's Avatar
Default 1982 245 gl no start
I'm having trouble diagnosing a issue with the old brick. I started about two weeks ago, she starting to stall at a red light so I gave her a little gas and the muffler exploded. I managed to drive home. the next day she would not start. This is what she is doing... when I turn the key she will fire, but she'll rev to 5000 rpm and stall ( thats not giving any gas) if I do give some gas she'll studder a bit than stall. Now every time I try to start her there is a poping snapping sound from the left side of the block followed by a sizable puff of smoke. I have replaced the plugs and wires, checked fusees , fuel relay and both pumps seam to be working fine. Anyone ever had this problem? Any info help !!!!! stranded in Quebec
Old Oct 1, 2011 | 10:06 AM
Jetswede's Avatar
Hello, Sorry to hear about your problem....CHeck the timing....sounds like it's firing at the wrong time....u said that u replaced the plugs and wires....did u connect them back in the correct order?? I recently had a no start or an intermittent start problem that I was chasing. Had my 83 244gl towed twice to Volvo to diagnos after i relaced the wires, the coil , the rotor and the dist cap....along with the fuel pump relays....
turned out the be a cracked #12 fuse....what the heck ! It was doing it's own thing and made contact whenever it wanted too.
good luck !
SlickNerd
Jan 25, 2011 06:25 AM
SlickNerd
Jan 15, 2011 05:22 AM
SlickNerd
Jan 15, 2011 02:23 AM
TestPoint
Jul 15, 2009 06:39 PM
TestPoint
Jul 13, 2009 12:48 PM
