1982 245 Headlight Warning Light
Old Oct 8, 2013 | 11:16 AM
Matt McDaniel's Avatar
Default 1982 245 Headlight Warning Light
Hi everyone!
I just purchased a 1982 245. I replaced the low beam lights, and now the warning light comes on when I turn on the headlights, which are working fine. Any suggestions on how to make the light go off?
Old Oct 8, 2013 | 02:23 PM
the bulb out sensor works by detecting any difference in the current between the two sides, it does this with counter-wound coils around a reed relay.
clean all connections in the low beam circuit. make sure both bulbs are the exact same type. make sure both headlights have good ground connections.
on a car that old, as a matter of principle, I would replace all the crappy aluminum/tin fuses with proper copper/brass ceramic european fuses. I get these from ebay, they are sold as 'mercedes W124 fuses' (W124 is a Benz 300E/300D/etc from the 80s/90s), enough to do 2-3 volvos is maybe $15. the ones sold in american autoparts stores are the silver junk ones. clean the spring contacts in the fuse holder with a soft clean rubber pencil eraser.
unluckily, I don't have the 1982 greenbook (wiring diagrams), only 1975-1980 and 1984 on.
looking at a 1980, the headlights aren't fused, the only connectors shown are near the headlights. On an 84, which has the quad headlights, same thing, no fuses...
the headlight low beam power goes into the bulb failure warning sensor on pin 6 (green) and comes out on pin 2 (blue, left side) and pin 7 (also blue, right side light). this failure sensor is buried under the dash on the drivers side, and looks something like a frozen OJ can, with a round connector on the rear-facing side. the ones I've seen have all been red-orange, but they are from newer cars.
the headlights are grounded at the front of each fender, right next to them. if either of these grounds is a bit resistive, that will light the failure light as the current will be unequal.
if all this doesn't help, remove the stupid warning bulb from the dashboard, nothing will be harmed
Old Oct 8, 2013 | 07:58 PM
Thanks Pierce! Great info.
Old Oct 9, 2013 | 04:24 AM
oh whoa, IPD has a kit of those 240 fuses for cheap.
30 Piece Fuse Kit for 240 & 260
Old Oct 9, 2013 | 09:36 AM
Pierce -
I had the new low beam in the high beam spot. Nice, huh?
Old Oct 9, 2013 | 01:39 PM
well, that would do it! as I said, its the difference in current between the two sides that triggers the light. high beams aren't checked, just low beams, parking, and brake lights.
SlickNerd
Jan 25, 2011 06:25 AM
SlickNerd
Jan 15, 2011 05:22 AM
SlickNerd
Jan 15, 2011 02:23 AM
TestPoint
Jul 15, 2009 06:39 PM
TestPoint
Jul 13, 2009 12:48 PM
