Installing an amplifier
Old Oct 8, 2013 | 04:44 PM
Shaggin240wagon's Avatar
Default Installing an amplifier
Im trying to find a good location to route my power wire through the firewall. Anyone know a good spot? It's a 240 wagon. Thanks
Old Oct 8, 2013 | 06:06 PM
right under the left side hood hinge should be a rubber plug with some 'nipples' you can cut off to feed a wire through.
see red wire here. this was several years ago, but I seem to recall poking it through from the driver side and then fishing it out and feeding it around the strut tower alongside a bunch more wires, to connect it to the 'positve terminal' on the relay bar.
Old Oct 9, 2013 | 10:03 AM
Problem solved. Thanks Pierce
Old Oct 9, 2013 | 01:47 PM
FWIW (about $0.002), while I've always routed my stereo wiring along the drivers side door sill, between the carpet and the rocker, I saw a document from Volvo that said to route stereo etc stuff down the right side of the transmission hump, to the left of the passenger seat. I think maybe this was because there's no factory wiring there, so it will get less interference.
Frankly, since in-dash decks started coming with 50x4 class D amplifiers built right in, I haven't installed an external amp except maybe for a sub (and the last wagon I put a sub in, it was always getting in the way). my current car, a 1992 740, I put 6" component speakers (JL Audio) in the doors, and run them directly off an alpine with '50Wx4' (yes, I know, thats 50W of 'music power', not RMS dc to daylight, but its still plenty to drive speakers at any sane volume). Had to spend quite a bit of time fixxing high volume buzzes and rattles after that install, hah hah! the speakers and most of the door panel hardware are now RTV'd in place.
gordon368
May 11, 2006 09:08 PM
85 760Turbo
Feb 16, 2006 10:13 PM
85 760Turbo
Feb 13, 2006 09:52 PM
Swish
Sep 18, 2005 11:19 PM
mattdoc88
Jun 21, 2005 01:02 PM
