1983 240 fuel relay maybe, maybe not
Old Jul 9, 2014 | 02:50 PM
tomc761's Avatar
Default 1983 240 fuel relay maybe, maybe not
hi,
I was driving home the other night in my '83 240 DL wagon, and all of a sudden the oil light went on and I lost all acceleration. I got off to the side, and the engine stalled. It turns over but doesnt' catch. I tried jumping the fuses to see if my fuel pump would go, and the jump seems to indicate that it's the fuel pump relay. So i opened it up and discovered I have no green six pin relay, instead there's two white 5 pin relays. I replaced those, but it still didn't start.
So the question is, am I missing something and those two relays are not related to my fuel pumps? What else could it potentially be? The fuses seem ok. Both the intank and main pumps were replaced with used parts two years ago.
thanks
tom
Old Jul 9, 2014 | 02:53 PM
older 240s had 2 separate relays instead of the later double relay.
that said, me thinks its time to do some troubleshooting with a volt meter.
Old Apr 9, 2019 | 02:00 PM
Dannyak's Avatar
Default Volvo fuel relay
Originally Posted by tomc761
hi,
thanks
tom
i know this is an old post , but I have a similar problem , did you end up finding the problem and repair?
Old Apr 9, 2019 | 02:27 PM
dannyak, do you have a 1983 240 with LH II injection?
Old Apr 9, 2019 | 06:57 PM
Dannyak's Avatar
you know I’m not sure not too knowledgeable on these Volvo’s . By what i see in the pics it looks like I might
Old Apr 9, 2019 | 06:59 PM
Dannyak's Avatar
When I test the fuel pump with a power probe I can turn it on . I can chase the wire back to the fuse panel and even to the control module . Don’t know what turns on the pump which key power.
Old Apr 10, 2019 | 03:57 PM
the two relays (or two halves of the later single relay), one part comes on with ignition power, and provides power to the ECU itself while the other relay/half is told to turn on by the ECU when it senses engine rotation via the hall sensor (or CPS crank sensor on later cars), and that 2nd relay/half is what powers the fuel pump.
Dagaan
May 11, 2014 03:26 PM
my-volvo-rocks
Apr 28, 2013 05:21 AM
goldbrick88
Feb 16, 2011 11:50 AM
cshort
Jan 4, 2008 05:38 PM
pirate240
Jul 12, 2006 12:49 PM
