1984 240 oil on spark plugs
Old Jan 19, 2011 | 10:24 PM
WMDS's Avatar
Unhappy 1984 240 oil on spark plugs
Hi from Vegas, i got a 84 240 with high miles. Changed the spark plugs and found fresh oil on them. Is this from a piston ring leak? welp! what to do?
Thanks all
Old Jan 19, 2011 | 10:46 PM
NCVOLVO940's Avatar
could be worn rings, or a bad valve seal... any discoloration in the oil?
Old Jan 20, 2011 | 12:03 AM
WMDS's Avatar
The oil looked a little green. I will try and post some good pix by the weekend. Thanks for the reply
Old Jan 20, 2011 | 12:05 AM
WMDS's Avatar
Could this be a expensive job? how much work?;will it be a rebuild?
Old Jan 20, 2011 | 07:14 AM
swiftjustice44's Avatar
Of course it could be expensive. If the engine needs piston rings it is customary to disassemble the engine to get to them. Honestly, you just haven't provided enough information. How many miles on the engine. Has it been sitting up for quite some time. Was the engine running ok prior to seeing the oily residue. Have you done a compression check. Are the spark plugs the correct heat range and gap. Do you know the difference between oil deposits and gasoline fouled? Does the car visibly smoke?
Old Jan 21, 2011 | 04:40 AM
WMDS's Avatar
Right. the car has 260k miles. i have no clue how the og owner took care of the car as i am the 3rd owner now. the guy i purchased it from said a old man owned it. its oil not carb or deposits. it did not sit or so the sellers say. it does not smoke at all. will not pass smog. thanks for the help and for the replys. my subaru needed a head gasket at 255k miles but there was no rad fluid in the engine so we went foward with the rebuild. that job was just over 1k bucks. that is commen for the flat 4 with high miles so im thinking this is going to be around the same price range
Old Jan 21, 2011 | 06:44 AM
NCVOLVO940's Avatar
never heard of the oil looking "greenish", usually it'lll look like a chocolate milkshake...
you might just want to start off by changing the oil & filter, and a real good tune up (plugs,cap,rotor,flametrap,air filter,fuel filter) and run some good fuel system cleaner, such as lucas or seafoam. run about a half tank through before checking the condition of the plugs again, and go from there.
Old Jan 21, 2011 | 02:59 PM
WMDS's Avatar
thanks man. i start looking onto them. after looking around under the hood it looks like she needs a new intake manifold gasket (idle flux) and 2 motor monts. also when taking off from a stop or slow speeds i hear a thump from the back passanger side
Old Jan 21, 2011 | 04:14 PM
WMDS's Avatar
Question
can someone tell me where the flame trap is? details on this site are not very clear
volvoadventures.com/howtodoflametrap.html
Old Jan 21, 2011 | 07:01 PM
NCVOLVO940's Avatar
if I remember right, the housing sits under the intake, around the #3 & #4 runners... there will be 1 large line running up from the side of the engine, and 1 large line and 1 small line coming off the top. be careful taking this apart,as the plastic usually gets pretty brittle and will not hesitate to break with only slight excessive force... if you have the plastic flame trap in the housing, you can usually get it out by inserting a small screwdriver from the bottom...
hope this helps,
Darin
volvoQ's
Apr 23, 2011 10:00 PM
futbolfan15
Apr 2, 2010 09:56 PM
NYSpeedRacer
Jun 5, 2008 05:31 AM
dcox612
Sep 29, 2005 09:37 PM
