1984 volvo 240 GL no abs brakes not working
Old Jul 5, 2022 | 12:39 AM
Sulaymaan's Avatar
Default 1984 volvo 240 GL no abs brakes not working
the brakes were working i had to replace a rear brake line, from the brake junction block to the rear one and all of a sudden they were out, the pedal is sinking and when i bleed a brake the pressure keeps breaking. Heres where it gets real when i press the brake the idle drops im thinking its the booster but im not sure.
Old Jul 5, 2022 | 08:18 AM
act1292's Avatar
When you replaced the rear brake lines did you remove both rear calipers at the same time? If so, you might want to check to make sure they are installed on the correct side of the car. If the left & right rear calipers got swapped then the bleeder valve will be on the bottom and will never bleed properly. Also, did you use the proper bleed sequence?
Malbone
Jul 30, 2019 12:15 AM
Nichals
May 13, 2016 06:39 AM
Zovar
Mar 7, 2016 12:59 PM
sancy
Feb 17, 2012 09:54 AM
mpower989
May 19, 2009 07:19 PM
