Slight brake delay
Old Jul 29, 2019 | 11:42 AM
Malbone's Avatar
Default Slight brake delay
I have a 1990 240DL with about 227K miles. The brakes work fine in the city. On the highway, if I haven't tapped the brake pedal for 15-20 minutes, the next time I use it there is a slight delay before the brakes kick in. I'm thinking it is a question of having the brake lines bled, but I would appreciate any other suggestions.
Old Jul 29, 2019 | 01:59 PM
does the pedal feel mushy when this happens ? thats the number one sign of brakes that need bleeding.
Old Jul 29, 2019 | 02:12 PM
Malbone's Avatar
No, the pedals depress about the same as always. The only difference in feel is that when you depress the pedal and nothing happens for half a second, you get a sinking feeling in your gut.
Old Jul 29, 2019 | 02:52 PM
if you feel the hard resistance in the pedal, the brake pads should be firmly against the rotors. there's no mechanism there that can introduce a delay in braking.
if you're not familiar with servicing brakes, you should bring it to a reliable mechanic ASAP to have the brakes inspected.
Question: does a 1990 240 have ABS? under the hood you'd see a fairly complex box clearly marked ABS with a bunch of gold brake lines going to, they are on one side or the other (on my 740 it was on the left/drivers side of the engine compartment, forward of the spring/shock tower). a defective ABS unit can do funny things to braking, but usually you feel it 'throbbing' when pressing down on the pedal.
a *non* ABS 240 has dual circuits to each front wheel, they both have to be bled, if one circuit isn't working correctly, you're supposed to get a red BRAKE warning light on your instrument panel, and you'd have half your normal braking power.
Old Jul 30, 2019 | 12:15 AM
lev's Avatar
lev
Most likely a master cylinder issue.
Nichals
May 13, 2016 06:39 AM
sancy
Feb 17, 2012 09:54 AM
AnathemaS80
Nov 12, 2010 11:16 AM
mpower989
May 19, 2009 07:19 PM
darkdelta
Apr 17, 2009 05:28 AM
