1985 240 Idle Surge
Old Mar 9, 2014 | 01:41 PM
newmex999's Avatar
Cool 1985 240 Idle Surge
My 85 240 wagon has a nasty intermittent idle surge. When stopped, I need to keep my foot firmly placed on the brake in order to keep the car from taking off!
I have replaced the IAC and checked the hoses for leaks and have found nothing.
Any suggestions?
Old Mar 9, 2014 | 02:32 PM
with the IAC unplugged, the idle should drop to 500rpm (in park or neutral, no A/C, fully warmed up engine).
clean the throttle body, and adjust the idle air bypass screw til it is doing 500 under above conditions, and make sure the idle switch is engaging (0 ohms at idle, open circuit anywhere above idle), then plug the IAC back in and it should idle at 700.
Old Mar 9, 2014 | 06:21 PM
newmex999's Avatar
For the most part, she idles ok. Every once in a while, while I am stopped, if I don't have my foot firmly on the brake the car will try and take off. Also, have significant stumbling upon acceleration.
Old Mar 9, 2014 | 07:42 PM
Clean the throttle body.
Old Jun 15, 2014 | 02:34 PM
newmex999's Avatar
Smile
Resolution to the stumbling/hesitation on acceleration and idle surge-
Had to replace both alternator belts as they broke when alternator came loose.
Replaced alternator bushings and re-tightened everything. Also replaced distributor cap.
Both the hesitation and idle surge are gone!!!!!!!!!!!!!!!
If anyone has insight into this let me know?
inilegna
Sep 25, 2013 09:35 AM
jonathant1977
Nov 24, 2008 07:32 PM
leebae
May 31, 2007 05:55 PM
zmontgomery
Jan 26, 2007 08:45 PM
johnnyvolvo
Dec 29, 2004 03:39 AM
