1985 240DL Steering Rack - is this a ZF replacement rack?
Hi all,
I believe, from looking at my (leaking) steering rack, that mine is a ZF type rack. This company comes recommended, but the rack shown on their site looks slightly different to mine. I'm referring to the length of the driver side gaiter, and the casting around where it mounts to the cross-member.
http://www.carsteering.com/viewpictu...80-00496&code=
If one of you kind folks wouldn't mind taking a quick look at the attachments, and giving their opinion, I'd be grateful!
Thanks,
Tim
Thanks,
Tim
Anyone have any pointers out there for getting the u-joint off of the input shaft or the steering column? I started my rack replacement today and all was going smoothly until I tried disconnecting the u-joint. Got both bolts loose and it just won't let go.
