1985 245 DL Cold start after 6 years
Old Nov 25, 2018 | 05:39 PM
bunchman's Avatar
Default 1985 245 DL Cold start after 6 years
Good afternoon fellow volvo peeps. My ide is still rough because I haven't had the time or money to do much. However, the car runs great for the most part. When I depress the brake pedal all the wqy while idling, the engine will die if I don't let up on the brake. If I don't depress it all the way to the floor it will keep running. As always all input and ideas are appreciated. I think I read something about this in a YouTube video about smoke testing for vacuum leaks. It also makes a high pitch squeal sometimes when the brake pedal is depressed. Again, thank you Volvonation.
Old Nov 25, 2018 | 09:20 PM
lev's Avatar
lev
It has to be vacuum related. The high pitch squeal is air escaping from the booster and it has to be a good size leak. Have someone else step on the brake while you listen/watch for a leak from that area. The smoke machine for leaks detection is expensive and not needed except for minor leaks that are hard to pinpoint...
Old Nov 25, 2018 | 09:29 PM
bunchman's Avatar
Default Rough idle
Lev, thanks for the input. I have my own DIY smoke machine that i made. Where is the best place to use it to check my exhaust?
Old Nov 26, 2018 | 05:05 PM
lev's Avatar
lev
You don't check the exhaust, you'd check the vacuum system by introducing the smoke in the intake manifold.
Old Nov 26, 2018 | 05:31 PM
bunchman's Avatar
yes I understand that . But I still need to have someone applythe brakes while I'm under the hood. Right?
rargenargle
Aug 19, 2019 11:30 PM
dajson
May 30, 2013 11:48 AM
petax
Jul 2, 2012 06:21 AM
940glowner
Nov 29, 2010 05:43 PM
razak-ms
May 18, 2009 10:03 AM
