1986 240 wont fire up!
Old Jul 13, 2011 | 04:13 PM
JordanM_L's Avatar
Default 1986 240 wont fire up!
I have a 1986 240 dl Volvo manual trans. It would occasionally die. I was always able to restart it after a few long moments of waiting. One day while driving to get pizza the car died and never started again. The symptoms are: all electronics still would work, the car would turn over but never fired up.. I believed that it was the wiring harness because there were many bare and old wires exposed, so I replaced the entire harness. Believing that it was the coil to blame, I used my buddy’s from his 1975 244 volvo. My car still will not fire up (meaning my coil is fine). I am getting enough fuel because I can smell it after pumping the gas. Any suggestions?
Old Jul 13, 2011 | 06:00 PM
Joewill2848's Avatar
Banned
Did you check to see if the distributor is delivering power to the plugs?
Old Jul 13, 2011 | 06:06 PM
JordanM_L's Avatar
yes but i didnt see any spark. also, the wiring harness i replaced the old one with was from a 1984 240. Are there any differences i didnt catch?
Old Jul 13, 2011 | 06:32 PM
Banned
that I do not know about the differences between the 2 harnesses, but if your not getting any spark there is your problem, sounds like a distributor issue
Old Jul 21, 2011 | 08:58 PM
JordanM_L's Avatar
Default Diagnostic test show that coil is good, no spark after distrbutor
I have a 1986 Volvo 240 that would often stall. Finally it would not start at all. It would turn over fine, but not fire up. I checked the coil using several methods found on chat rooms and all seemed to indicate that the coil was working fine. I even used to coil out of my buddy's car. Still it would not start.
I'm getting no spark at the distributor or at any of the plugs. The distributor seems to be the problem. Is there any way of knowing for sure? I would hate to buy one and then find out that it was not the problem. I can't see any bare/shorting wires at the hall effect sensor either.
Should i replace the distributor?
Old Jul 22, 2011 | 10:27 AM
bubba240's Avatar
Make sure the rotor turns while cranking, suggesting the timing belt is good. If so, see the attached ignition trouble shooting diagram.
Old Jul 22, 2011 | 12:05 PM
JordanM_L's Avatar
thanks Bubba240, we have already used the is truouble shooting guide. the guide sent us to the destributor. are there any other things that i should check before replacing the destributor. or just blowing my car up in frusteration.
Old Jul 22, 2011 | 12:09 PM
JordanM_L's Avatar
how do i test the ignition module?..how do i know if its bad or not?
Old May 10, 2022 | 12:18 AM
Dennis Mullin's Avatar
bad ignition control module( located passenger side of engine bay #1346107 and they go bad equals car will notvstart.Parts geek sells em for$240.00 and junkyards for $30.00 they control the ignition and often people overlook them.
Old May 10, 2022 | 08:42 AM
Goldenblock's Avatar
Default 240
Yes big culprit on the 240
if your other test dont check out
I have Oem Bosch units available for shipping.
Excellent condition and tested
L&D volvo parts atl
Old May 10, 2022 | 08:43 AM
Default 240
L&D volvo parts atl
Old Jan 30, 2023 | 02:35 PM
The problem is the" Ignition control module on the right side inner fender(#1346107)and when they die?'' No friggin way your car will start.They last many years& " Poof" go out lite" THAT" I have a half dozen for the " 240" years "85,86,87 call me at(714)631-9890 Dennis in Anaheim California.Sell them for$50.00 guaranteed" 6 months too!
Old Jan 30, 2023 | 02:39 PM
No! It's the ignition control module.When they die," God himself couldn't start the car.Thats why it's called" Ignition Control- it controls every part of the ignition system.Distributors rarely go bad.Modules!?they die," In the blink of an eye.I own two" 1986 Volvo 240s,am an old fart& seen just about every problem& 100% that is it.
Old Jan 31, 2023 | 06:48 AM
BigOle87Wagon's Avatar
Following. Will prob need ign cntrl module.
waltonsauto
Feb 1, 2012 10:31 AM
waltonsauto
Jan 31, 2012 12:40 PM
amersue
Dec 31, 2009 04:11 PM
roostermod
Mar 27, 2009 02:14 PM
Dreas
Jan 23, 2009 09:32 PM
