850 GLT Cranks But Wont Fire
Old Mar 25, 2009 | 01:35 PM
roostermod's Avatar
Question 850 GLT Cranks But Wont Fire
Hello,
I have a 97 850 GLT that suddenly died on me on the hwy. The engine turns over but doesnt ignite. getting fuel to the rail, no spark at the plug, faint spark at the coil wire only when grounded, does not arc to ground though. Changed plugs, cap & rotor no success. Trouble codes are a p0115 eng. coolant temp & a p0722 Output speed sensor. A volvo tech is pretty sure that the output speed sensor is to blame. Does anybody know if this a common problem or the fix? i dont want to start buying sensors and coil or relays obviously if its wont fix it. any help would be greatly appreciated.
Thank you.
Old Mar 25, 2009 | 06:52 PM
Check the plug for the Cam sensor.
Old Mar 27, 2009 | 02:14 PM
roostermod's Avatar
thank you, i will check that out.
nightmarevolvo
Feb 4, 2023 06:20 PM
FlyingVee
May 29, 2013 06:05 PM
detestroet
Mar 5, 2012 08:11 PM
chadman551
Sep 16, 2009 09:38 AM
chadman551
Sep 14, 2009 07:35 PM
