1986 240DL No Brakes Lights
Old Aug 12, 2010 | 10:47 PM
GdGuy's Avatar
Default 1986 240DL No Brakes Lights
Replaced both rear assemblies. Have tail lights, back-up lights, and turn signals...but no brake lights (or 3rd brake light in window). Have checked switch under brake pedal. Get good reading on Fluke meter when depressing brake. Fuse is good. Is there something I am missing under the dash??? H-E-L-P!!!!
Old Aug 17, 2010 | 01:21 AM
redbottle's Avatar
how about the wiring or the bulb? is the bulb a single wire inside or double?
Old Aug 17, 2010 | 08:48 PM
GdGuy's Avatar
Gosh, never thought to look at the brake light bulbs! I bought the new assemblies complete with bulbs. New membranes, etc. Should it be a two-wire bulb? Or, a one wire? BTW, this is the 240 sedan... Thanks.
Old Aug 17, 2010 | 10:54 PM
GdGuy's Avatar
Redbottle: Single filament bulbs in the brake sockets. Ohmed with Fluke meter. Good. Also took the bulb failure sensor from its socket and dismantled to look at the solder connections. All appeared good, but touched them up with the iron, in hopes...still no brake lights. Have ordered another sensor. Hope this fixes the problem. Will let you know when it arrives.
Old Aug 18, 2010 | 10:38 PM
Msvolvo's Avatar
should be 2 metal connections on the bottom of the bulb for brakes lights 1 for everything else if I am not mistaken I believe the brake bulbs are 1157 and the bulb holder should also have 3 metal pieces on them unlike the others with 2. Good luck please continue to share we all have these problems at one point or another.
dogon
Jul 2, 2008 09:52 AM
joeylea
Nov 27, 2006 09:44 PM
zx6star
Oct 26, 2006 02:00 AM
cb400fred
Apr 10, 2006 10:55 PM
Carlo_Scialla
Jan 5, 2006 10:51 PM
