1986 740 death wobble and idle
Old Mar 27, 2019 | 05:55 PM
Ross Miner's Avatar
Default 1986 740 death wobble and idle
Problem 1: I have a 1986 740 GLE wagon and the other day it had trouble idling. When I turn it on the car jumps back and forth from 800 rpm to 500 rpm. When I put the car in gear it struggles to keep the engine going and requires assistance from me to not stall. This usually only happens when it’s cold. Problem 2: When I go above 60 mph the car shakes violently but when I go below 60 it drives normally.
Old Mar 27, 2019 | 09:02 PM
violent shaking usually is caused by a bent wheel
your idling problem could be a lot of things.... there's a microswitch in the throttle body that tells the ECU the throttle is at idle, and when it is, the ECU monitors engine RPM and pulses the IAC (Idle Air Controller) to maintain a suitable idle. with the IAC disconnected, and all loads turned off, in neutral or park, a warmed up engine /should/ idle about 500-ish, the IAC brings it up to 700-750,a nd maintains it there whether its in gear or not.
cold, the engine should idle at about 1000 rpm
things that can mess this up...
1) something was fubar, and someone messed with the idle settings on the throttle
2) the IAC is gummed up
3) the idle throttle position switch is flakey or non-functional
4) excessive air leaks, especially the rubber hoses to the IAC
5) .... something I didn't think of....
Old Mar 29, 2019 | 01:39 PM
silvermine's Avatar
If I were you i would immediately check your ball joints on both sides.
Old Mar 30, 2019 | 05:53 PM
Ross Miner's Avatar
i checked the ball joints and they are completely shot
Old Apr 1, 2019 | 10:19 AM
silvermine's Avatar
glad you could find out before something really bad happened at speed...
lukem
Jun 13, 2018 04:00 PM
moms940
Feb 7, 2015 04:47 PM
newmex999
Jun 15, 2014 02:34 PM
Bobby Pelletier
Aug 29, 2012 06:34 PM
lambo
Jan 14, 2012 12:21 PM
