1987 240 wagon trailer hitch
Old Jan 22, 2014 | 11:05 PM
Samilton's Avatar
Default 1987 240 wagon trailer hitch
Does anyone know what trailer hitch will fit a 1987 240 wagon? Mine did not come with one and none of the junk yards around me have any volvos with them on. I was curious if anyone has bolted a different trailer hitch assembly on? Or close matches?
thanks,
Sam
Old Jan 23, 2014 | 12:16 AM
I've always used Drawtite hitches, they still sell new ones that fit 240s, also for 7/9's sedans and wagons. afaik, each of these is a different hitch. hitches are too critical to mess around with, $150 or whatever for a new one with new hardware that bolts right up is fine by me. you'll definitely need a 1/2" socket set and torque wrench. if your 25 year old car has never had a hitch, you'll want to chase the threads out before you try and install the hitch. I used a knife to scrape out a bunch of the undercoating from the threads (the 4 'nuts' are captive welded into in your rear subframe), sprayed some WD40 up them, and ran one of hardened bolts that came with the hitch reciever up and down each hole a couple times before I even tried to install the hitch, and it went a WHOLE lot easier. I forget if you need to trim the rear valance on a 240 to fit these, you certainly do on a 740/940.
Old Jan 23, 2014 | 08:25 AM
admasters's Avatar
Default if you're interested
I have a receiver hitch and ball from a 92 960 in CT. The receiver subframe is still attached and has the multipin connector. (I don't know if that's any good). PM if you're interested.
Andrew
Old Jan 23, 2014 | 10:48 AM
the 960 one won't fit on a 240.
Old Jan 23, 2014 | 12:01 PM
admasters's Avatar
Default didn't know that...
too bad.
aggiengr
Jun 2, 2009 07:39 AM
autoxray
Sep 21, 2008 11:03 PM
EdLuVa
Aug 15, 2006 11:01 AM
740TurboGuy
Jun 6, 2006 12:45 AM
jman9895
Aug 26, 2005 01:16 AM
