Cruise control quit
Old Jan 20, 2014 | 05:25 PM
dbacchi's Avatar
Default Cruise control quit
Hello. I need some help getting the cruise control on my 1988 244DL to work again. It was working until I changed my odometer gear and mistakenly attached the wrong wire to the cruise control on the gauge pod. Any ideas as to where I could start?
Thanks,
Dave
Old Jan 21, 2014 | 06:12 AM
act1292's Avatar
If you connected the red/white wire to the double male lug on the back of the cluster, then you may have fried the taxi output pin of the ITT 2115 chip on the speedometer board. Does your speedometer & odometer work?
I had an old instrument cluster laying around so I swapped the chip and it fixed my problem. Need a soldering iron, a solder sucker or solder wick to get the chip out.
Old Jan 22, 2014 | 07:17 PM
dbacchi's Avatar
Oops... I was concerned about that, but they are working. The fuse is good as well.
Old Jan 23, 2014 | 05:40 AM
act1292's Avatar
Yeah. I had the same symptoms. Speedo and odo worked - just the cruise control didn't. Mine is a '90 240 and I was also getting a 3-1-1 code (no speed signal) on the ECU. I checked all the wiring diagrams and verified that the speed signal to the ECU and the cruise control came off the taxi output of the 2115 chip. Since you have a LH2.2 fuel injection system, you can't check the codes.
If you are handy with a solding iron and have a solder sucker, you can find the ITT 2115 chip on ebay. They are relatively cheap and the repair is not that difficult.
Old Jan 23, 2014 | 03:19 PM
dbacchi's Avatar
Sounds like a plan. Thanks for the help!
russ
Mar 8, 2017 10:10 PM
rspi
Mar 7, 2010 06:13 PM
Oly Volvo
Oct 26, 2009 10:37 PM
jfikentscher
May 31, 2006 09:58 PM
CFGVolvo850
May 24, 2005 12:38 AM
