1988 volvo 240 dl failed smog
Old Sep 22, 2006 | 02:37 PM
joanvito's Avatar
Default 1988 volvo 240 dl failed smog
my 1988 Volvo 240 DL failed smog today and the person there said it was running both very rich and with very high emissions. It also is shaking when it is idling and at higher rpms. Is there anything I could do at home or with minimal cost?
Old Sep 22, 2006 | 04:24 PM
Mr Yuck's Avatar
Default RE: 1988 volvo 240 dl failed smog
How close were you?
Are you due for an oil change?
Drive the car for about 20 minutes right before taking it in.
Tune up
The most common things are, spark plugs, spark plug wires, distributor cap and rotor, and of course the gas cap. Replace these and 99 percent of the time you're in good shape.
Clean your engine
Use Seafoam. Put some in the gas tank, engine (a day before you change oil) and through the intake. It helps clean out carbon build up and clean out your exhaust. Also, don't go into smog with your check light on. Check light = automatic failure. Last but not least, get your engine timed right. If your engine isn't timed to spec with OEM standard, you will fail. Also, having improper timing will either cause your motor to be lean or rich, which will result in having higher readings in the gases.
The last 2 were taken from a page I found through google. These are all generic tips but I'm sure they can be transferred to a 240.
Old Sep 22, 2006 | 08:42 PM
Make sure there isn't a vaccum leak at the intake manifold.
Old Sep 28, 2006 | 12:10 PM
cbevis's Avatar
try clearing the codes....this was a problem for me in Georga and clearing the codes temporarily fixed the problem
Old Sep 28, 2006 | 09:19 PM
AlexR's Avatar
ORIGINAL: tech
2nd that
More then likley its either a vacum leak or a bad FPR {fuel pressure regulator}
akpasta
Feb 9, 2015 06:59 AM
mandobizar
Sep 16, 2013 12:20 PM
swenkenb
Apr 18, 2012 09:07 PM
tassadar30
Apr 23, 2007 11:07 AM
tassadar30
Jun 22, 2004 01:16 AM
