1988 Volvo 245DL Overdrive
Old Dec 10, 2014 | 08:52 PM
  #21
smeha's Avatar
Update:
-Removed solenoid and started car for about 5 second (to clean holes)
-put everything back together
-oil level on dipstick is max
Still no help
Old Dec 11, 2014 | 10:36 AM
  #22
silvermine's Avatar
Originally Posted by smeha
Great idea, will try it today.
How do you clean solenoid? Oo
just use solvent make sure the passages are clear.
Old Dec 11, 2014 | 10:38 AM
  #23
silvermine's Avatar
Update:
Still no help
not sure what to suggest now .. maybe try the block off plate idea
to eliminate all the electrical components out of the equation.
Old Dec 11, 2014 | 02:02 PM
  #24
if you have a compressor, you could try clip-lead powering the solenoid out of the car with 12V (+ to the wire, - to the metal body), and using a rubber tip 'jet' nozzle to blast air into the inner hole, see if it comes through the outer hole. If you cycle the power while doing this, it should open/close the ports.
but I think we're rapidly approaching the 'you're tranny is toast' point.
Old Dec 11, 2014 | 05:38 PM
  #25
smeha's Avatar
I forgot to mention, solenoid is opening and working.
when i was cleaning holes, i left solenoid hanging on the wire and grounded.
turned key to turn on solenoid and spray it thru hole on solenoid with brake cleaner.
Summary:
- it opens
- its clear
- there were a little oil inside of solenoid.
Old Dec 11, 2014 | 08:57 PM
  #26
smeha's Avatar
Last step i'm going to try is that i'm going to do a by pass plate out of old solenoid. (drill a canal between 2 holes)
If after that i won't get my 4th gear back, then my transmission is toasted.
Thank you everyone, i will let you know when i try that.
Old Dec 12, 2014 | 06:29 AM
  #27
silvermine's Avatar
i would try the blowing out trick again before you put the block off plate
on. i still think the internal passage to o/d is blocked. you have nothing to lose at this point by doing that again.
Old Dec 12, 2014 | 06:00 PM
  #28
smeha's Avatar
Update:
- drilled a canal between hole in the old solenoid
- going to put it in next couple days and go from there
Old Dec 13, 2014 | 06:38 PM
  #29
smeha's Avatar
Update:
- put on my transmission home made by pass plate
- shifts in 4 gear
Thank you ALL! the topic can be closed.
Overall instead of ~$150, it all cost me with full fluid flush and stuff $300+
On Monday i'm going to talk **** out of IPD about the malfunction part they sold me and its after shopping there for years and spending there couple thousands.
Old Dec 14, 2014 | 06:28 AM
  #30
silvermine's Avatar
glad you got it sorted out. i know in my case it was driving me crazy not having 4th...
question- did you blow out the passages again before putting the block off plate on?
Old Dec 14, 2014 | 10:23 PM
  #31
smeha's Avatar
No, i did it once before that, read the topic. when i was putting plate i was already so pissed that this thing wouldn't work after so much tests/money/time so i just installed plate and went for a test drive.
Old Dec 15, 2014 | 02:24 AM
  #32
silvermine's Avatar
it's just a little confusing, if the 'new' solenoid was working as you said it clicked etc
when you put 12 volts on it .. then what was different? the solenoid should have acted the same as the block off plate....
Old Dec 15, 2014 | 02:36 AM
  #33
smeha's Avatar
The hole looked smaller than on original solenoid and i think it was partially opening.
Old Dec 15, 2014 | 07:39 PM
  #34
Donovan62's Avatar
Hello everyone,
I own 1988 Volvo 245DL Automatic Transmission
Long story short. My overdrive wasn't shifting into 4th gear half of the time.
1) Replaced overdrive relay(the one next to glove box)
2) Checked wiring to overdrive solenoid
3) Replaced overdrive solenoid with new 2 o-rings.
Notes:
- Button was redone few years ago.
- Kickdown cable was replaced and adjust 2 years ago and working fine
However, now after replacing overdrive solenoid it wont shift into 4th gear at all even on 70mph(freeway speed)
Also, It makes clicking sound on overdrive solenoid when you press button.
Please help me. I have couple things what else could be wrong, but i will wait for replies.
I also had a similar issue with my 1987 Volvo 240 GL Sedan. At first I tried replacing my OD Relay and that didn't solve the issue. And replacing the solenoid was more than I wanted to put out for repairs. So, I did the next best thing. My mechanic took the solenoid off and two points (forks) on the inside, being part of the solenoid, he filed them down and then put the solenoid back on. The OD button does not work anymore but, it will go into OD again as needed. If the other ways don't work for you as the others have suggested then this is a third alternative for you.
Old Dec 15, 2014 | 08:27 PM
  #35
Donovan; you must not have read the whole thread, thats where Smeha is now, he took his old solenoid, and ground the space between the holes, and its working.
catch-22, he DID buy a new solenoid, which SEEMINGLY tested out OK, yet DID NOT WORK. I'm confused why, as it really doesn't take much hydraulic juice to activate the circuit, its pressure, not flow.
Old Dec 16, 2014 | 07:26 PM
  #36
smeha's Avatar
Could be its not fully opening or the hole placing is not matching hole placing on the transmission.
Old Dec 17, 2014 | 11:06 PM
  #37
smeha's Avatar
Thats what i'm about to send to IPD.
Old Dec 18, 2014 | 01:59 AM
  #38
silvermine's Avatar
it will be interesting to hear what they say. i got mine from fcp but it appears to be the same brand as offered by ipd. could be bad right out of the box... unusual but not unheard of.
Old Dec 18, 2014 | 03:55 AM
  #39
parts quality isn't what it used to be. Some Volvo brand parts are showing up made in China.
Old Dec 27, 2014 | 07:02 PM
  #40
scrumblero's Avatar
Glad you got it working!
I had to replace the solenoid in my 245 again today. Thank god I ordered 2 last time so I would have a spare since the last couple have only lasted a year or so (14 months this time) I am getting pretty good at it though! took less than 40 minutes this time..
