1988 Volvo 740 Turbo stalls 10s after start
Old Jan 27, 2024 | 02:30 PM
mrt740's Avatar
Default 1988 Volvo 740 Turbo stalls 10s after start
I recently bought a non-running 1988 Volvo 740 Turbo (B230FTLH 2.2 AW71). The fuel pump and filter, injectors, fuel injection relay, and spark plugs were recently replaced by the previous owner. Car would run on starting fluid. Tested the fuel pumps by disconnecting the line and pumping gas into a bottle. They definitely work. While testing the injectors noticed one connection to the injector was broken, I fixed the connection and the car started for 10 seconds before cutting off. Unplugged the MAF and it would idle rough for a long time. Then discovered leaks and positive pressure in the crankcase. Cleaned the PCV system (issue seemed to be the fully clogged vacuum line.) and the car idles with no leaks. Cleaned the MAF sensor also. At this point the car starts and runs with the MAF plugged in. Runs good from 2-4k rpms. When idling it seems to try and find the proper rpm but when it dips to 900-600 ish rpms the car runs real rough and sounds like an old diesel starting on a cold day or stalls. Will start easily but often stalls 10 seconds later when rpms drop. Any ideas what could be causing this?
Old Feb 1, 2024 | 11:05 PM
Psaboic's Avatar
Is the check engine light on and if so have you read the codes?
Old Feb 3, 2024 | 08:56 AM
act1292's Avatar
'88 has LH 2.2 FI and does not have the blink box for reading codes.
Old Feb 3, 2024 | 03:47 PM
Psaboic's Avatar
Sorry, forgot it was an 88. For some reason I thought it was a 90 like the one I am working on.....Duh.
Iridium_Spiral240
Jun 12, 2023 09:26 PM
mattem
May 14, 2020 08:39 AM
Patrick Bouchard
Apr 22, 2019 04:42 AM
detick
Oct 13, 2011 03:53 PM
WagHag
Oct 28, 2008 12:16 AM
