1989 240 DL won't shift into 4th gear.
This morning on the highway cruising at 75 mph I noticed my 240 seemed to downshift on its own. There was no noticeable loss of power, just higher RPM's it seemed. I checked the tranny fluid later on at work and the fluid level is good, smells ok, good color. The vehicle has about 200K miles on it. On the way home it will not shift into 4th gear. Could it be something simple like the overdrive solenoid or relay? Thanks in advance for any suggestions.
IPD has an OD solenoid bypass kit. With that you will not be able to take it out of OD manually.
http://www.ipdusa.com/product.asp?st...hStartRecord=1
elchingon2002
07-22-2014 07:09 PM
