1989 240 starts then dies immediately!
Old Jul 7, 2011 | 12:31 AM
Daltino4's Avatar
Default 1989 240 starts then dies immediately!
I had to replace the crankshaft sensor and the mass airflow sensor. A buddy told me that was probably the only problems but it still won't idle worth sh*t. Has anyone had similar experiences or know what's wrong?
Old Jul 7, 2011 | 02:23 AM
these are for 740/940 cars but your engine is the same B230F, with only minor differences (240 doesn't have the 'radio supression relay', and many components are in somewhat different places, especially electrical stuff like relays)... anyways, I'd go through these troubleshooting suggestions
Engine Tune and Performance
I *think* a 89 240 has LH 2.4 (my 87 has LH 2.2).... the LH 2.4 has a onboard diagnostic thing where you can read codes and execute diagnostics from a little blinky box thats under the hood. The earlier LH2.2 doesn't have this. see
Engine and OBD Diagnostic Codes for the OBD codes on a 740/940, the 240 are almost identical.
Old Jul 8, 2011 | 12:44 PM
Daltino4's Avatar
I figured out what's wrong with it. A rock flew in through a space into my flywheel and dented it all up. That's why my crankshaft sensor was destroyed. We turned it by hand and popped all the dents out, and it started right up. I don't think anyone could've seen that coming.
Old Mar 25, 2020 | 09:02 PM
straubman's Avatar
so it was the crankshaft sensor after all? Having the same issue that’s why I ask.
Old Mar 25, 2020 | 09:21 PM
i thought flywheels were machined solid steel ??
edity: oops, 9 year old thread dredged up from the graveyard.
Old Mar 26, 2020 | 06:43 AM
straubman's Avatar
I always thought that too, would the crank sensor create the symptoms I described?
Old Mar 26, 2020 | 04:47 PM
lev's Avatar
lev
I bet it wasn't the flywheel that was dented but the tone ring which controls the CPS pulses! If the flywheel gets dented, the engine would be damaged-- good luck straightening it out!
Old Mar 26, 2020 | 05:05 PM
its been too long since I saw a volvo flywheel.... I thought the CPS read holes drilled right into the side of the flywheel next to the gear teeth that the starter engages ??
Old Mar 27, 2020 | 09:13 AM
jagtoes's Avatar
My 89 740 is like that. Just blind holes drilled in the side of the FW. No way I think you can damage it so I would suspect the sensor itself.
AridianSea
Apr 2, 2017 08:12 AM
Gazolba
Jun 20, 2015 07:40 PM
Ethrty
Jun 10, 2010 03:08 PM
cleiby
Aug 29, 2007 05:39 PM
joanvito
May 1, 2007 03:23 PM
