1990 240 DL Transmission line connection
Old Apr 29, 2020 | 09:06 AM
NH240DL's Avatar
Question 1990 240 DL Transmission line connection
Good morning, I am new here. My transmission line is corroded and begining to drip.The lines are available but the 2 connectors - 1239669 - are elusive. Any suggestions on finding the conectors or on how to remove existing lines from connectors I already have without having everything fall apart.
Many thanks,
Robert
Old Apr 30, 2020 | 06:11 AM
act1292's Avatar
I had to do this job on two of my 240s. The fittings are simple flare fittings. I think I ended up using steel brake line and fabricating the pieces myself. As far as the flare fittings, I just went to napa or ace hardware to find flare fittings with the correct thread. To do this though, I had to remove the old fittings and bring them with me to ensure proper fitment. I realize it's a littler harder if that is your only means of transportation.
Old Apr 30, 2020 | 01:54 PM
make sure you use flare wrenches on those fittings. thats a special 5-sided wrench designed to get a good grip on said flare fittings.
kinda surprised Ace etc would have metric flare fittings.
Old May 1, 2020 | 06:06 AM
act1292's Avatar
The ace hardware near me has an extensive supply of different fittings both metric and standard. Not sure all ace hardware stores are that good. They seem to vary from place to place.
Old May 1, 2020 | 01:25 PM
miner have extensive metric hardware, like nuts and bolts, but not plumbing fittings.
Butch70
Oct 22, 2016 03:48 PM
Clacquam
Nov 22, 2014 09:14 AM
jonqu
Aug 10, 2013 09:56 AM
anjp
Apr 2, 2012 01:39 PM
spamedic
Jul 27, 2011 07:08 PM
