1990 240GLE UK model - won't start
Old Nov 9, 2007 | 05:18 AM
esmedunae's Avatar
Default 1990 240GLE UK model - won't start
Hi,
I'm new to the 240 (used to run a 740, though). Mine's a UK spec 1990 GLE, which has run well up to now. Yesterday morning I started her, she ran for about 10 seconds and stopped as I reversed out of my parking space. When I tried to restart, the engine turned but that was all. I definitely have a spark, there's gas in the tank, and the air supply seems to be OK. The pump fiuse was not blown, but I've replaced it anyway. My brother in law reckons there may be an interia switch/emergency cut out to the pump which may have activated. I don't have a manual that covers the model, so I'm stumped. Can anyone help?
Is there indeed a fuel cut-off switch (and, if so, where is it and what does it look like)? Can it be reset or bypassed?
How can the pump be accessed? Do I need to remove the gas tank, or is it accessible with the tank still in situ? If the pump needs to be removed, is it a long difficult job?
Thanks
William
[IMG]local://upfiles/13259/242730E8396C455CA4DA36EFA91C7D98.jpg[/IMG]
Old Nov 21, 2007 | 08:52 AM
rgraves1's Avatar
Default RE: 1990 240GLE UK model - won't start
Can you hear the fuel pump when you turn the key on? Is it sending any codes? mine was doing the same thing and my crank speed sensor was bad, but there was a code...
topkat418
Jun 17, 2014 04:43 AM
morty1999
Jul 16, 2012 05:22 PM
dldunckel
Jan 20, 2010 07:02 PM
pmvictory
Dec 6, 2005 01:26 AM
dalborn
Jul 21, 2005 09:52 PM
